I have found to drain the bilge it is most effective to remove the center drain plug at the lake before heading home.
It is annoying removing the rear seat to get to it.
I do not use the table that has a base plate in the rear seat.
The center drain plug is directly under the post base plate.
By installing a 5" Sea-Dog deck plate in place of the post base I can now get to the center drain plug with ease.
