replaced the steering cable in my 05 22v I used an 18 footer the same as the one that was in it. I re routed it over the tank and the 18 footer had more than enough slack so I'm glad I didnt use the 19 footer as I heard some people have. I did the whole job in just under 2 hours (like 1 hour and 50 min. lol but still under 2 hours)if anyone has 05 22v or a close to and are going to do the cable if you have any questions just shoot me an mesage and ill try and help out.
How to change a steering cable.
This is a sticky topic.
I am going to do a friends 2005 24V this weekend and I did mine last season.
I did not read all the posts again, but I do remember 2 things. I got the 19' cable by mistake and it did work fine, but no shorter. And, I cut down an 1 1/8" open end wrench to get to the big nut on the cable. Made things much easier. Good luck. The results are unbelievable.
Last week I started to replace both my steering cable, and helm. I was advised to change the helm due to both age, and wear. This will be my third steering cable. For the additional 50 bucks, what the heck. I started with the steering wheel and hub. Let me preface that I am no master mechanic. Just pretty good with my hands and tools. the steering hub, and helm were a breeze. It took me longer to find a steering wheel puller, that to replace the entire unit, which only took about an hour total.
I read all the advise thats been posted, and I thank you guys soo much !! Lee's tool list was on the money, but I would like to add a pair of Bolt Cutters to cut the cable, and do yourself a favor, get a 3" 1-1/8" open end wrench for the coupler. It will save you alot of time, and knuckle skin. After cutting, and removing the old cable, I fished a wire from on top of the tank to the cable opening near the helm. I used the fish wire to guide the new cable over the top of the tank. I did this by myself, and only took about 3 trys to get it. After that, the rest was very easy. The stubby wrench makes all the differance in the world. All in all, the entire job took me about 3 hours by myself ( I have no freinds) Lol. Grab a buddy, and I bet you could do it in two hours complete. I was a bit nervous to attemt this, but dont hessitate. You can do it. Just be patient, and think it out first.
P.S. The steering is now effortless !!"Just Surf Damn it"
- 1 like
Hours are somwhere around 300, not quite sure due to my hour meter reseting itself last summer after the rains in Shasta. I havent had the boat out this year yet. My tower broke last year so Proflight did a redisign so I went with them again. THe boat is at Chucktronics right now getting the tower wired up. I should be picking it up tomorrow or Friday. I will see if I can get through another year with the old cable but it was getting tight last year. I will let you know.A man can only be beaten 2 ways - give up or die!
Well everyone, wish me luck!! Heading out to the Colorado River in Yuma, AZ tonight and plan to do this on my 2004 22i first thing tomorrow morning! I'm not the most mechanically inclined person, but I have a mechanic friend out there so I can scream for help if needed.
Is there any particular reason as to why you can't just tape the 2 steering cable together and while pulling the old one out up by the steering wheel, pulling the new one up at the same time?
Thanks!
Originally posted by InsideOut104 View PostWell everyone, wish me luck!! Heading out to the Colorado River in Yuma, AZ tonight and plan to do this on my 2004 22i first thing tomorrow morning! I'm not the most mechanically inclined person, but I have a mechanic friend out there so I can scream for help if needed.
Thanks!
If you don't have the bigger tank like I do, it won't be hard at all though.
Originally posted by Tanner View PostSo I just got done doing the cable on the 24V.... I pulled the floor and you got about two feet to run the cable under the floor until you get on top of the fuel tank. I dropped it in from under the foot well and had a buddy use a metal bar to keep it on top of the fuel tank while I fed it and he could reach it. It popped right out. Took us less than a minute to totally feed the line through. Hardest part was getting to the tiller arm. To do that We took an electric impact from the starboard side of the motor (had to fish it in from the port side though) to get to the bolt, and held the 1/2 drive on the nut to keep it from turning. Done in 5 secs with that.
2 people and done in 25 mins! Not bad at all!
*if you've never done one b4, just remember you can extend the cable by turning the wheel to let it connect to the swivel... mine wouldn't reach and I couldn't figure it out. Then it hit me. DUH!!!
Carla
