All, When I bring the boat back into the dock, there are times where the engine will rev to 1500RPM and stick there for a few secs when I go into neutral. It does not happen all the time and is always when I shift out of forward. Any ideas on what could be causing it?
Also, a stupid question - how do you rev the engine without putting it in gear? The only way to move the throttle forward is to pull up the ring underneath (which engages the transmission.)
Thanks
Thanks
