The Jabsco Impeller is one of the easiest impeller to swap out.
What you will need is Impeller, and a 5/16 socket and ratchet. A straight blade screw driver may be used instead of a socket.
You will need to remove the four screws, plate and gasket from the front of the housing.
If needed you can use a impeller removing tool to remove the impeller.
If you do not have a removing tool you may use two screw drivers and pry the impeller out of the housing.
The new Jabsco impeller will come with some lubricant to coat the new impeller with before you align the spines and insert the new impeller. After you insert impeller apply the new gasket, plate and four screws.
