I thought I'd share my experience replacing my vinyl on my boat. The pictures here are with my vinyl already removed and I plan to take some pictures of re-installing the cushions when I get them back from my vinyl guy.
To remove the center bow seatback, I had to remove my bow speakers to reach 4 nuts and washers that held the thing on. The remaining seatbacks were fastened with deck screws directly into the fiberglass from between the seams on the seatbacks. I was able to get most of them with a screwdriver, but a few had rusted heads and disintegrated when I tried to unscrew them. I used a flat pry bar to separate the seatback from the side of the boat. I found the screws and used a hammer to tap against the screws, which promptly snapped. I then trimmed the leftover screw with a heavy duty wire cutter.
So, here's what it looks like with everything out:
