Servicing Your Transmission and V-Drive
This is a sticky topic.
    When checking fluid levels, should the trailer be level or the engine? The engine is mounted at an angle, so it's tilted a little when the trailer is level. Or should I put the boat in the water and then check? Seems like there should be a proper way.
      I always work with engine fluids with the boat floor level. That is what it is on the water.
      Sent from my SM-G950U using Tapatalk
        I currently have ATF in both the transmission and V-drive. If I change to SAE30 like some have recommended, are there any issues with mixing ATF and oil if I can't get all the ATF out? Should I just stick with ATF?
          Good question. I am getting ready to do mine and would like to know also.
          I just checked my manual. It says to use ATF in both.
          It also says to DIP the DIPSTICK to check fluid levels.
            20180506_201543.jpg 29.97bg20180506_201543.jpg20180506_201614.jpg7
              The Tige’ dealer in Denver recommended ATF in the tranny and 30W in the drive for the ZF hurth 45 IV setup.
              It’s not a big deal to pump out as much ATF as you can and refill the drive with 30W. If it were me I’d change the fluid a couple times within a couple outings because I’m OCD like that and it’s only a quart of 30W each time you do it.
              You’re definitely not gonna hurt anything by mixing the two in the drive. It’s just gearing internally.
                I've got a question about changing the oil in my RV-26 V drive (boat is '01 21V). The first step in the manual says to remove the plug that is opposite the strainer. I was unable to reach that plug with a tool since it's about 1/2" off the bottom of the boat and inaccessible because it's on the backside of the V-drive. Instead, I siphoned oil out with an oil extractor and then removed the strainer (I also cleaned the magnetic plugs). Is it okay that I wasn't able to get the drain plug off?
                Also, anyone have any suggestions for catching the oil when I remove the strainer? It's such a type spot and so low to the bottom of the boat that it's hard to get anything under there to catch the oil that comes out. I cut up a gallon milk jug and slid the base under, but it didn't hold enough volume and had to be scrunched up when I pulled it out. The end result was a mess of oil in the bilge under the V drive. I'm glad I siphoned out most of the oil first.
