The paddle wheel on my 2006 22V is gone on the speedometer pickup on the bottom of my boat. I must have hit a stick, piece of wood or something. Anyway, I need to replace it. From the inside of the boat it does not look like a difficult repair. I am wondering if anyone can confirm or correct my assessment of how difficult this will be. I live 100+ miles from the dealer and don't want to take it in if I can help it. Thanks.
Speedometer pickup replacement
Is your speedometer a Perfect Pass? The Perfect Pass paddlewheel is held in by a SS pin that it spins on. My guess is your pin is also missing. PP sells the Paddlewheel Kit or you can go directly to the manufacturer, Airmar - http://www.airmar.com/pdfs/install/17_274-01_r02.pdf
You could put a new one in with pliers from below or pull the plug assembly out from above.
If it's not a PP speedo chances are the pickup is still an Airmar sensor. You would need the model no. from the housing.
