I am still thinking about implementing the ballast system the same way that Malibu does it; instead of one large hole of for a scoop or transom hole, there are three small holes on the bottom for each pump. I don't believe that it would fill as fast as the scoop, but you could still fill up while underway. Second advantage, there are no hand or electric waste gates. Water will only go in the bags when the pumps are running. I know some have complained about there are now 3 points of failure, but what are the real probablities of that happening? Also, with smaller holes, if you do have a failure, it is better than having a big failure with the bigger holes. Malibu has been doing it for years, I don't know....still thinking about it.
DIY Ballast Install
Okay. In the bottom picture is the pump , the black thing is a 1 1/4 inch mack washer and the nut. Below the pump is the 2 inch to 1 1/4 inch pvc reducing fitting. The bag on the bottom has the mack washer. The I took off the nut and used silicone to attach it to the bottom of the 2 inch to 1 1/4 pvc fitting. The nut fits perfectly on the bottom. I then put Silicone on the threads of the pump and pushed it through the pvc fitting and threaded onto the nut on the bottom of the pvc fitting. The mack washer will seal and it gives a little bit of play. In the top picture you can see the mack washer between the pvc fitting and the pump. Hope that helps. You must remember to cut the threads on the pump shorter before assembling as they are way to long.
Hope that helpsLet it be!!!
Ok that makes sense but how are you going to attach the pump at the end if you want to add on? really long socket extension?Everything happens for a reason
I already siliconed the nut in the fitting. All i need to do is unthread the plug at the end and thread the pump into the fitting and be good to go. Again if you get the right pvc adapter the nut is a tight fit in the bottom of it. If you want to make sure it will never move use pvc cementLet it be!!!
Here is a link showing the picture of the pumps thru the adapter and the nut on the bottom. The last pump is where i had cut off the extra threads on the pump
http://www.tigeowners.com/forum/show...5&postcount=87Let it be!!!
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
Originally posted by Moki View PostI am still thinking about implementing the ballast system the same way that Malibu does it; instead of one large hole of for a scoop or transom hole, there are three small holes on the bottom for each pump. I don't believe that it would fill as fast as the scoop, but you could still fill up while underway. Second advantage, there are no hand or electric waste gates. Water will only go in the bags when the pumps are running. I know some have complained about there are now 3 points of failure, but what are the real probablities of that happening? Also, with smaller holes, if you do have a failure, it is better than having a big failure with the bigger holes. Malibu has been doing it for years, I don't know....still thinking about it.
Where do you think would be the best place to put the holes? I am trying to envision how I would do it, and it seems that the intakes have to be between the stringers, you couldn't just go through the floor in the storage compartments. So then I would have 3 individual holes with pumps attached scattered throughout the bilge. I think that I would have to see how bu does it to understand how it might work without seeming cumbersome.Be excellent to one another.
Originally posted by CP3 View Postdid you use the tige through hull drains?Let it be!!!
I will try to get a picture of my neighbors to post, but the holes were fairly close together just in front of the scoop for the engine intake.
