Two of my neighbors each have 2002 21v Rider's editions and they both have it. I know they offered it as an option back in 2000.
Packing change overview
This is a sticky topic.
Guys, I have a more in depth tutorial up on my new website
http://www.wakeboatworld.com/index.p...d=22&Itemid=35
Visit it for more details on this process.http://www.wakeboatworld.com
[]) [] []V[] [])
Originally posted by dogbert View Postone drip every minute, according to spharis.David
Lubbock, TX
Originally posted by rpaxton View PostI have a 2000 year model 22i that has this same dripless seal on it. However, on my first lake trip I got a lot of water in the bilge and have no idea where it came from.
-Drain plugs
-Thru-hull fittings (Water intake, ballast intake, tracking fins, strut, etc.)
-Engine cooling hoses
-Riders coming in and outCommon Sense is not so Common
Thanks Zad!
We took the boat to the lake yesterday to look for the possible leak. The prop shaft is good and I can't find any leaks. We were not out as long as it was pretty cold, and we did not appear to take on an unusual amount of water (took on some at launch b/c of the angle of the boat ramp right now -- way steep due to lack of water). I put some PVC pipe under my port side exhaust to keep it more in line with the back of the boat. A couple of years ago I found this was the source of a leak. Tige cut the insulated exhaust pipe short on this side and tried to make it work (I gues quality control slipped a little in 2000). So I am not sure if that was my source again, or if it was just a fluke. Maybe the boat already had some water in it that did not drain out when I jacked the boat up prior to hitching it up. I will continue to watch it and keep my ballast pump handy in case I need to bail water fast....
I headed out to the boat and located the pin and proceeded to pull it out.
We Creat New Fashion for DVDs, Running for Your Desired CSI Lasvegas Season 13 DVD
