How to make your own Indo Board
Originally posted by bfrank View PostGood one!!!!
I wonder what will happen whe you get a fat a** like me on a two liter bottle?
My guess it would blow out!!
That was my thought at 230 lbs I wouldn't trust a 2 litter bottle. I thought I would by one of those Hinekien mini kegs and use that with water inside (no way I would waste beer like that)
Another way to keep the bottle and board from seperating is to run an old bike tube under there. Cut the tube to the length you need with the board and bottle and then run a round head screw though the deck and with some washers and an nut to hold the rubber tube in place. It should still roll find from side to side but wouldn't send you flyingSuccess is the ability to go from one failure to another with no loss of enthusiasm.
Winston Churchill
Originally posted by Coach View PostThat was my thought at 230 lbs I wouldn't trust a 2 litter bottle. I thought I would by one of those Hinekien mini kegs and use that with water inside (no way I would waste beer like that)
that might just work i could buy a blank skate deck for 30-40 bucks for my local shop (infinityskateshop.com) and maybe a 2 lieter bottle for me because im only 155lbs if that!...but then again im only 14The sun never sets on a badass
Another way to keep the bottle and board from seperating is to run an old bike tube under there. Cut the tube to the length you need with the board and bottle and then run a round head screw though the deck and with some washers and an nut to hold the rubber tube in place. It should still roll find from side to side but wouldn't send you flyingThe sun never sets on a badass
Originally posted by Coach View PostGood deal. I have not tried yet. I am not so sure I will find something strong enough for my 230 lbs with out it exploding or crushing it that is cheapThe sun never sets on a badass
Originally posted by Coach View PostGood deal. I have not tried yet. I am not so sure I will find something strong enough for my 230 lbs with out it exploding or crushing it that is cheapMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostI'm thinking about trying a piece of 4" dia PVC! I like the idea about the innertube/rubber to keep it from slipping off.
We made ours in 30 min.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Originally posted by dogbert View PostI made one of these for my kids...went to local skate shop for grip tape. All you need is some high quality 3/4" plywood (finish grade) and 4" PVC. Taper the corners, sand the edges and you're done.
We made ours in 30 min.Success is the ability to go from one failure to another with no loss of enthusiasm.
Winston Churchill
