Originally posted by chpthril
View Post
Bow Drains Install
This is a sticky topic.
Well, the bow storage is done. No more wet carpet to mildew and stink
2 - 2.5 hours total time.
Herculiner 1qt $29 @ Pep Boys
old or cheap brush
Didn't spend alot of time in prep work because I dont care what it looks like. This was about solving a water/mildew problem. After pulling out the carpet, I found that Tige does have drain holes from the bow storage to the console storage, but it is covered by the carpet. The problem with this, is that I need the 2 console storage areas to stay dry.
I pulled up the carpet.
Cleaned most of the glue/carpet fuzz using a sanding disk on a 90* angle grinder.
Glassed over the factory drain holes and added sealer around my bow drain holes/tubes.
Vacuumed and wiped down area one last time.
Brushed on the liner
Cleaned up.
Stir the liner real good and stir often
Use brush. Roller wanted to soak up the liner vehicle and leave the granules.
Throw brush away, not worth the time to clean out all the granules.
Where are the holes at?? Is it possible for someone like me who doesnt want to pull up all the carpet and look for the holes or install new ones to cut a hole in the carpet so the water goes out the intended holes?Common Sense is not so Common
Originally posted by zad0030 View PostWhere are the holes at?? Is it possible for someone like me who doesnt want to pull up all the carpet and look for the holes or install new ones to cut a hole in the carpet so the water goes out the intended holes?
If I had known the drain holes were there, I would have filled them in long ago. I would rather have standing water in the bow, that I have to shop-vac out, then have water running into the storage console where we put all our stuff that we want to keep dry.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by Big Wave View PostVary nice job. This is going to be my thanksgiving week project.
I sure would like to hear from Tige why they set it up to drain into the storage consols. I bet that 90% of the people with these boats are putting stuff they want to keep dry in these compartments.Let it be!!!
A note to anybody doing this, MAKE SURE you use plenty of masking tape and paper on areas you don't want covered! It does not clean up very easily and it's permanent if you don't clean a spot before it dries. I learned the hard way on my truck bed.Other than that, Mrs. Lincoln, how was the play?
