This is an old question but I have yet to see a solution. Has anyone solved this problem?
Lowering pylon on 2000 2100V
Well sometimes it is not as Ez as KoolAid makes it sound. Mine will NOT come out I have removed the entire bracket now Placed it in a 5 ton press.(Yes i soaked it in pb blaster) didn't budge. Soaked it in more Pb for a couple more days took it to a friends with a 20 ton press. Again Didn't budge!!!! Now it is riding around in the back of my truck until I decide if I really want it out or not. I saw a mod on "wake garage" to make it go up and down as needed was going to do that. Warning if you don't have a lot of time you might want to stay away till you do.(If you haven't been there you should go) Anyway they can be a bit%*&. to get out. I might have to split my base and re-weld.
Gumby, Did you call the Dr after 4 hours of the pylon not going downMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
- 1 like
I will get mine out.one way or another. Just wanted to say sometimes they don't come out easy. I was just busting your ba!!s a bit because your advise is 99.9 all the time. Chpthrill is still 100 I am going to call the Doc.LOLso funny looked in the rear view minor today saw it in the bed of the truck. had to chuckle.
heat no good since expands the metal the pylon made of. removed rack in attempt to lower the pylon but still no success. continue to spray with special stuff supposed to loosen corrosion but still no help. appears if when brand new, if not lowered periodically, gets cemented in place. i bought boat 2016. would like to lower it for winter to be able to safely lower tower and rest on rear instead of precariously on top of pylon, also allowing cover to fit better. any new ideas, pls continue. thanks. walt m/moondoggy/2000 21v
I had to take mine to a guy who could cut it out. The problem was that I had a stainless telescopic pylon attached to a steel mount. Those metals don't mix well and since it wasn't lubed at all, they fused via some kind of metallurgic reaction. If you can find a shop to do it, that's what I would do.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
