How to tighten or check the tighness on alpha z tower
    I have an 09 RZ4 with the alpha z tower. We are new to this boat, and while cruising around 25mph and some bumps, the tower seems to move quite a bit.
    Is there a way to check how the tower is attached to the boat and tighten anything?
    Thanks.
    IIRC, there are 2-3 nuts on studs, accessed from the bottom side of the deck. Socket on long extension. I think they might be 7/8".
      So I quite randomly took a picture of the under side of the alpha z mounts last week. This is looking from the front on the starboard side.
      I have no idea how you could teach them. I would try going in from the rear locker and try and figure out a way to reach it.
        Thanks!
          If you aren't able to weasel an extension in there you will have to remove all the nuts from interior panel(7/16 wrench) and remove the panel. That's what I do when you have to replace the tower based anyways.
            what is the interior panel, would you tighten from the front or back to try and get a 7/8" socket to the base?
              seat back
