MP 6.0 impeller
    MP 6.0 impeller
    I changed my impeller im my Marine Power 375 hp 6.0. The dealer sold me a replacement Johnson 812B, but it is 1/8" shorter in length than the Jabasco model. Will this cause an issue if it is not tight against the ends of the housing? I installed it and cannot get any water flow.
    Yes, if impeller has space between it's housing front and rear it won't be able to suck water.
      Some of the 2004 Tigé boats had a Jabsco pump that looks like the Johnson pump. They do indeed use a different impeller.
        My pump is a Jabasco for sure. Do you know what the part # would be and if there is a cross up to another manufacturer?
          I am not 100% sure but this is the only jabsco specific impeller we have in stock. Took a picture of dimensions so hopefully you can verify.
            Yes. yours should be 18777-0001-P.
              Perfect! Thanks for your help on this.
