Swap my tower for a Z tower
    I recently purchased an '08 RZ4 and and really wanting to put the Z tower on it. Is that an option, if so what's the price on doing it?
    I looked at doing this on my 06, the trouble is the hull or more specifically gunnel was significantly re-enforced to support the Alpha. If you are dead set on the upgrade there would be some significant Fiberglass work that would need to be done to allow for proper mounting. (although the RZ has a different hull so you may be able to do it without significant modification). I look at boat salvage yards that had totaled Tige's and found an alpha that way. Though I am sure Tige has one laying around.
      Thanks for the response, I ended up speaking directly with Tige and they basically said the same thing "mass amounts of fiberglass work.. Ill keep what I have for now.
      Thanks,
        Someone put this Samson tower on their RZ4 it looks awesome.
