Hi,
I just finished installing a Fresh Air Exhaust on my 2014 R20, which has dual exhaust, using the new trim tab mounting brackets. I took a few photos along the way so I'm posting some of them to help anyone else in a similar situation.
First, the before photo: IMG_20160212_080109834.jpg
Here are my measurements for the screw spacing on the trim tab hinge. (The other side is symmetrically the same.)
I marked the middle of each exhaust and then measured the centre-to-centre distance for Larry at BoatPipes.com:
Removing the flappers and installing the adapters was pretty easy:
Both adapters are installed (for now, without silicone, but if I were doing it again, I would just do it once
and pointed up, as designed:
Each hose was about 3.5 inches long, and Larry said it's OK for the pipes to butt against other, so I marked off 1.75 inches with a piece of tape, slid the hose onto the pipe, and installed a clamp temporarily:
It turns out that one of the uppers screws on each side of the trim tab hinge is actually a bolt with a lock nut, so I used the lower screws instead. The outer lower screw spacing is 2 inches... the bracket came pre-drilled. Here's what they look like at this point.
The brackets that came with my order were straight (90 degrees), so I needed to bend them about 8 degrees port and starboard so they lined up with the bolt in the FAE elbows. Larry said to stick them in a vice and get a long pipe for leverage. I took a guide bar off my trailer to use as the long pipe -- worked great!
I shortened the threaded rod to make it easier to work with, but still an inch or 2 too long.
(More in next post.)
