Shouldn't be too difficult, but wondering if anyone has submitted instruction for this yet.
Is there a how to on oil change for Raptor engine Z3?
Here is a link to a manual for the raptor in case you didn't get one with your boat. The process is pretty simple and has plenty of pics in this manual for the everyday diy'er
http://www.indmar.com/Libraries/Manu...nual.sflb.ashx
Its pretty easy! Warm the engine up and then shut if off and take the hose for the oil that is clipped to the side of the block and run it out of the drain plug of the boat. The oil will flow out pretty easily when warm, we also use a little 12v sucker pump thing to get it all out. The oil filter is remote and comes fairly easily...most of the time. We actually had to warantty an oil filter housing because the guys at Malibu/Indmar got a little over zealous putting it on lol. Then dump your oil in and measure it once the boat it level.
I ran my drain line out the garboard hole and opened the end and nothing came out! I need to check why. I had to pump out about 5 quarts on my Indmar 350 with the SORRIEST PIECE OF JUNK fluid transfer pump in THE WHOLE WORLD. Spent an hour pumping, I could have made a gallon of spit quicker. But it's all I had at the moment. Learn from my mistake- buy the $50 oil/ATF fluid pump, don't go to O'reilley's and get talked into the $14 POS.
Originally posted by Surf75 View PostI ran my drain line out the garboard hole and opened the end and nothing came out! I need to check why. I had to pump out about 5 quarts on my Indmar 350 with the SORRIEST PIECE OF JUNK fluid transfer pump in THE WHOLE WORLD. Spent an hour pumping, I could have made a gallon of spit quicker. But it's all I had at the moment. Learn from my mistake- buy the $50 oil/ATF fluid pump, don't go to O'reilley's and get talked into the $14 POS.
Spend money on a good mityvac and you wont regret it!
Tigé Jedi
- Jul 2010
- 4302
- TN USA
MityVac 7400. ~$70 shipped to your door. You'll never look back, except to kick yourself for not buying one earlier.
You can connect it straight to the oil pan hose via the threaded fitting. A few minutes at the hardware store will get you the fitting needed to connect the MityVac's hose to the threads. Oil changes then become a 5-10 minute affair that you can do on the water. We do this several times each season. Easier than changing the oil in a land vehicle.
A MityVac 7400 should come as standard equipment with every inboard sold.
Originally posted by JLG View PostYes but the exhaust and fresh water parts do need water or they will overheat. Engine and heater are closed cooling only
Thanks again.
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by Epic View PostOk. How do I supply water to the parts that require fresh water? If it is possible. My last boat had a water hose adapter. I don't see that on the Tige.
There are also kits that will fit a hose connection directly into your incoming cooling hose, which would give you what you had on your earlier boat (our earlier boat had this, too). IMHO those are just another part to break or fail in some way, so I keep it simple and use a Fake-a-Lake. To each his own.
Finally: Don't engage the transmission while on the trailer. The strut bearing expects to be in water for cooling. Running the propshaft while out of the water risks overheating that bearing.
Tigé Jedi
- Jul 2010
- 4302
- TN USA
Originally posted by Epic View PostThanks for the help, everyone. Looks like the transmission fluid should be changed as well.
Since Z3 is V-drive that means I need 5W40 oil for transmission, correct?
Also, I didn't notice any notes for maintainence on the V-Drive. Any fluid change required on that?
