Hello,
I'm following the steps on the sticky thread on this forum about replacing a steering cable, but i'm stuck on the first step in that thread.
I have removed the seat box and floor exposing access, but now in step one it says, "You will first need to loosen the nut that attaches the cable and the support tube using a 1 1/8" wrench".
I can barely get the wrench onto the nut in it's location underneath the engine. However, there is only enough room to get about an 1/8 of a turn on the nut!! As such I cannot get the wrench moved and into place for turning any further
I've unhooked the water hose that was in the way but even so that's not enough access.
Who has done this before on the 2005 22v? Is there something else I need to remove to gain more access to get that nut loosened?
Thanks in advance!
Thanks in advance!
