Originally posted by Ruune
View Post
Rival Ballast Install
guests
Originally posted by da.bell View PostI have come to a conclusion and I think it will work. When you have the tube out and the children are tubing, do everything or anything to cause them to have a bad ride. When you do that, the next time they will think twice about tubing and would rather wakeboard or wakesurf...If I can be of any help at all, your in deep doo doo!
Originally posted by Moki View PostMost honorable and esteemed Talltigeguy, XPjim, Chpthrl and others,
I am still very tempted to forgo the whole manifold system and go directly to drilling a hole in the hull for each of my three pumps as Malibu does.
What think ye?
I agree with Tall, that the mushroom will allow you to fill on the fly, but not force-feed like the scoopAnyone know if this theory works?
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
What think ye?
My main concern would be what happens if say one of your pumps cracks and starts to fill the bilge. There is the 'OH CRAP' factor that I can put one brass valve in there and be very sure I can stop the bleeding immediately. If they are all separate, then you will need to do some detective work as the boat seems to be getting heavier. Maybe the flow would be slow enough because of the smaller hole the bilge pump could keep up?
Originally posted by chpthril View PostI agree with Tall, that the mushroom will allow you to fill on the fly, but not force-feed like the scoopAnyone know if this theory works?
I have the mushroom in my garage now. It will be a $40 experiment.
Be excellent to one another.
Finally got around to ordering the Rival system. Got it in and none of the install instructions have been updated. (You would think someone over at Rival would have read your post and updated the install instructions.)
As with your shipment, no screws were included for scoop. After reading some of the recent post activity, I may not even use the scoop, but in case I do, what size screws did you use for this?
Also, dougofkc mentioned "slicing scoop off of through hull". Forgive my ignorance, but what does that mean?
Originally posted by misfits1981 View Posttalltigeguy-Im not sure if this was mentioned but what size breakers are on the switches?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
Originally posted by GVelvet View PostFinally got around to ordering the Rival system. Got it in and none of the install instructions have been updated. (You would think someone over at Rival would have read your post and updated the install instructions.)
I think they were a #6 3/4 inch. Don't forget to get the stainless.
Another advantage of a mushroom instead of the scoop. No screws.
I still haven't put the mushroom on yet.Be excellent to one another.
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
I got around to putting the mushroom on this weekend...sort of.
I was worried that I should have used the 3M 5200 sealant, which is more like glassing the thing into the boat, but my concerns are resolved now. Getting the thing off of there was a bear to say the least. It never leaked, either. If I had used anything stronger, I would have had to just hammer and chisel it off of there.
The silicone sealed nice and snug. Once I finally got the nut off, which was difficult all by itself, the scoop would not come off. Even after removing the screws, the through hull was sealed to the hull in a major way. I finally got impatient and pried it off with a flat blade screwdriver. Each of the screw holes has some spider cracks next to them. Most of them are just about 1/2 inch. I think I will have it fixed professionally this winter. I put some gel coat repair on them and that will do a decent job of keeping the water out, but I think any discriminating buyer is going to see it as a hack job if they check it out when I sell this summer. It doesn't look real professional. I don't have the right tools or patience to make it look nice. I have to have the boat back together by Wednesday for the weekly run.Be excellent to one another.
I wonder if that is why they said to use 2" hole saw. So in case you needed to remove the scoop, it would be easier to come off?
I'm gonna make my run to the HW store and get everything in hopefully one trip. On the hose, when you say 1" or 2", do you mean Inside Diameter or Outside Diameter.
Also, I ordered these switches from Tige to match the other switches:Attached Files
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
Originally posted by GVelvet View PostI'm gonna make my run to the HW store and get everything in hopefully one trip. On the hose, when you say 1" or 2", do you mean Inside Diameter or Outside Diameter.
I filled a sack in the walkway today. Emptied it with a Tsunami...it emptied way faster. The goofy size Tsunami fittings are a curse to the world, but it might be worth working around them.
Got the boat out on the water to day. The mushroom worked fine. We hurried and filled the ballast, and it still works great. I do not think that there is any water coming in to the sacks when underway, but did not undo the hoses to check. I do know that we wakeboarded for 2 hours and my surf sack did not fill to capacity like it used to if I left the valve open...so I think the mushroom is a success. Will take the time to get it checked thoroughly at the reunion. That is likely the next time she will get out.Be excellent to one another.
