Engine Wall support in Rear Locker
    HI Guys, I have a jumbo surf sac in my rear locker, and when its filled, it breaks down the engine wall and rips the plastic railing on the bottom with the screws out. Does anyone have an effective way to support and stabilize this wall so it can be strong enough to support the fat sac in the locker when filled??
    Any tips are really appreciated!!
    I've had the same problem. For some reason this last time I put the screws back in (different holes), it hasn't moved in over a year.
      Several have made a reinforcement with metal straps. I had that issue and got some longer screws and used the same holes. One thing that I have done is made sure that the sac is moved right up against the outside wall, made even a little bunched. Since I have done that I have not had any issues.
        I used longer screws and added a few extra. Have not had the problem since and have done a lot of filling. So have used angle or channel aluminum the reinforce the board.
        Wake Up or Stay On Shore!
          Reinforce the plastic U channel with a foot of alum L bracket.
            I removed the plastic channel and use a 3/4 aluminum U channel for a replacement. I also added U-channel on the back side of the panels themselves to keep them from bowing into the engine compartment.
            You can see how I used the U channel to back the engine locker walls:
            http://www.tigeowners.com/forum/show...t=16220&page=6
              I just took my channels out and shot a bunch more finish nails into it to beef up the channel and then added a few more screws when I screwed it back into the floor. I also added a piece of alluminun angle at the top to give it some more support.
                This post contains useful information.
                sound hire
                  sound hire
                  No it doesn't!
