How to Remove floor in 24VE
    Looking on how to remove floor to replace steering cable on an '07 Tige 24VE. Master mechanic, any help would be great.
    Carla
    6 screws hidden in the carpeted trim along the base of the center seat "box". Behind it will be 3 large screws. From the v-drive lockers, you will need to access a bolt/nut on each side. The bolt head is a phillips head and is under the side seat and the nut is a 7/16 and is reached on the bilge side of the seat box. Once the seat box is loose, tilt it forward and lift it out/up. After that, the floor just lifts up at the back and is held in place at the front by a couple hooks.
      Is it the same for a RZ2? I can't seem to get my back bench up to release the hatch
        What year? There was a change in the floor access on the 2010 model I believe.
          Yep the Hidden screws! got it thanks.
