I had some very severe fading/oxidation on my lower color panel. In discussion with John at Hula Boat Care, I found that there is really no topical product to remove this oxidation, and color sanding was my only option. Having done this before to remove scratches, I knew what I was in for.
For those who don't understand, color sanding is the process by which you sand the finish with very fine wet-or-dry sand paper using water as a lubricant. You start with a courser grit, say 600, and move progressively up in grit rating. My process in this thread is 600-1500-2000.
Here is the issue I am dealing with:
As you can see, the fading along the bottom color panel is quite severe.
