Ok, so I probably won't see any of you in the grociery store or at the local tavern, so I am not going to worry about the snickers and finger pointing after I tell you what I did. But, help would be appreciated.
I moved my battery from the rear compartment by the motor to the to the cubby under the radio. I want to put ballast in the rear compartment. While attaching the battery box, I put a screw straight through the hull. Yes, you heard me right. I drilled through the hull, then I ran a screw into the hole. Why you ask? I just didn't think this one through. I though I was drilling into some type of sub-floor.
So, how does one go about fixing a screw hole in the hull?
