Bout to pull the motor out of said boat. What's the easiest way to pull it? Pull engine and trans together or what? Shouldn't be too difficult just need a little direction on the trans part. TIA
Pulling motor, 03 23v
From the sounds of it, and from looking at my own barco... I would think that tranny and motor at the same time would be the way to go. After pulling out the back seat, floor over the gas tank, and masking off all of the upholstery in case of drips... Then all you would need was an engie hoist tall enough to get over the boat. This way, when you get the new or rebuilt engine, you can re-mount the tranny(haha) outside the boat where you have some room to work and re-install by reversing the process. So if all goes well and Mr. Murphy stays out of things you should be all set! I've never done it before, so just my 2C! Good luck and post pics!
