Hi there,
I have a 20V with a bent prop, rudder and prop shaft strut. I got the rudder off, a new prop is on the way and the strut just won't budge at all!!
I haven't managed to get a single screw off it, I can't even seem to get the right screwdriver size (looks like a PZ5 to me - bigger than a pz4, but none for sale at the best local tool shops). I do have ph4 and pz4 screwdrivers, but they're bending and also starting to destroy the screws themselves so I've had to give up for the moment.
I was wondering if I'm approacing the problem wrong. I'm working from under the boat, but can the screws be loosened from inside the boat instead? It seems impossble as the engine fills the space!
So any tips would be very welcome - correct screwdriver size, correct technique, do the screws turn normally or are they reversed for example?
Thanks
Thanks
