Perfect Pass Broken
    Perfect Pass Broken
    Last year I pulled my boat up on an unfamilar lift to avoid a big storm and ended up bending in the speed wheel for my perfect pass and it no longer reads my speed correctly. I need to get it fixed. Any ideas? I've heard about a GPS version of the perfect pass that's easy to install. Anyone know about that?
    Thanks!
    Perfect Pass Stargazer is the GPS system: http://www.perfectpass.com/pp_star_gazer.html
    Call them to find out if it would be compatible with your engine.
      If you already have perfect pass your good to go and just need the upgrade kit.
      Common Sense is not so Common
        check the paddle wheel. It can get debris stuck in it. Spin it with your finger and see if it spins easily. Stargazer is awesome unless you surf or board on a river.
          Apprecaite the help fellas. I checked the paddle wheel, it was broke and got a new one for it. Replaced it I'm still getting the problem. I'm going to check out the stargazer upgrade. thanks!
