Originally posted by Jetdriver
View Post
How to perform a "quick winterization" (Marine Power engine)
This is a sticky topic.
I have an 08 22VE, and one thing no-one has mentioned is the fuel pump cooler. Mine has a hose teed off the port side hose to the exhaust riser that feeds the bottom a coil of pipe around the fuel pump. I pulled that hose off, and got about a half cup of water from that coil of 3/8 inch pipe.That is certainly enough to have split that pipe if it had frozen.
Man I should have taken pictures today. Honestly not hard to find. The knock sensor is just under the spark plug row on each side of engine. Only electrical plug there between the oil pan and spark plugs.
The drain for the exhaust manifold is right where the hose goes in on bottom side.
Well, well...my 15 year old and I found the drain plugs, knock sensors and tranny cooler line. Let's just say that they were way easy to find once I wasn't staring at the motor from 2" away. Back up a little and BOOM...there everything was I plain sight. We did it with flashlights too. I will try and take pictures when we put it back together in a few days after it dies out. Thanks. Easy to do, fun to learn, saved a few dollars...fun times.
