I have a 2003 22i and I just changed the steering cable but now the steering is out of alignment. Does anyone know the procedure to properly align the steering?
Steering alignment
Originally posted by Prary View PostI have a 2003 22i and I just changed the steering cable but now the steering is out of alignment. Does anyone know the procedure to properly align the steering?Common Sense is not so Common
Simply putting the rudder straight will get you close but not perfect.
Drive the boat straight. Make a mental note of the steering wheel orientation. when you are finished boating turn the wheel to the exact position you noted when going straight. loosing the four bolts holding the cable onto the rack. Enough to disengage the rack to cable gears. Rotate the steering wheel straight (if the bolts were loose enough the rudder will stay put). Now tighten the 4 bolts again.
