Ok I have the Taps 2 and it worked great last year.
First trip out this year and nothing. After doing some checking with my meter, I feel that the Lenco electromechanical Actuator is bad. This is why.
There are two wires that go from the control box to the Actuator. If I measured the voltage coming from the box, I get either 12vdc or -12vdc depending on the direction I press the taps switch. If I supply 12vdc to the wires going to the motor, nothing. (Is this correct, should I be able to supply 12vdc or -12vdc and make the motor move?) if so then, my motor is bad. This brings me to a second question. What is the part number for it! I found 101 B111 1 on it, but this number does not march any Lenco numbers I can fine.
This is for a 2004 SwitchV
Thanks for any & all info
David W.
David W.
