Looking at the bottom of my boat (98 2200V) I noticed that the prop shaft appeared to be offset to the left (passenger side) a little. When you look at it from the back, it does not go straight into the center of the hole in the bottom of the boat. Rather, it looks like it is pushed left and is almost touching. Are all shafts like that or is she bent?
Runs pretty well with minimal vibration otherwise
Bakes
Bakes
