I just replaced my fuel filter on my 2001 21V MAG MPI 315HP for the first time in probably 3 - 4 years. Didn't have any problem, but figured better safe than sorry. Now the boat won't start
It cranks. When you turn the key, the fuel pump runs for about 3 - 5 seconds, then stops. I tried the bleeder valve and at first there seemed to be fuel/air, then nothing. Held the bleeder valve open and cranked engine - nothing. Held bleeder valve open and turned key to on - again fuel pump ran 3-5 seconds, shut off, but no fuel came out. Is my fuel pump bad? What else can I check?
Thanks!
Thanks!
