How thick is the transom wall (2009 22Vé specifically)?
The PCM engine has a single exhaust. For structural purposes, I am going to install a dummy exhaust outlet as part of a Fresh Air Exhaust install and want to make sure I use the proper length of screws.
Also, does anyone know what size pilot hole to drill in fiberglass for a #12 screw? It is 7/64" for wood. Being a rookie when it comes to drilling into fiberglass, I don't know if that translates the same.
I will document the installation in a separate thread.
