De-Winterize Drain / Freeze Plugs
    OK I need some help with location of the last plug.
    I was able to locate where the Knock sensor and the corresponding drain plug on the Port side. I had two blue plastic wing-nuts that I put in the Exhaust manifolds one each side. I was left with two 11mm / 7/16 inch Brass plugs. Where do these go?
    Boat is 2006 22 Ve 5.7L
    Try the fuel cooler and the hose coming off the water pump.
