Can any one explane the difference between TAPS and TAPS II?
TAPS / TAPS II
I believe TAPS II came out with the Convex V hull. Function wise, they work the same and have the same effect on boat's attitude. Physical characteristics wise, the TAPS I has 2 rams, and TAPS II has 1. Some where in there there was a switch from a hydraulic pump to an electric motor but not sure if it corresponds with the TAPS to TAPS II change.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
We have a 97 Pre 2200 WT with the original taps. We are wanting to try surfing and I am not sure what I will need to do to get the required wake .
How much ballast do you guys think I will need ?You bet wakeboarding and motocross will drain the wallet in a hurry ,but not near as fast as teenage rehab
Originally posted by Grant View PostWe have a 97 Pre 2200 WT with the original taps. We are wanting to try surfing and I am not sure what I will need to do to get the required wake .
How much ballast do you guys think I will need ?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Hey, my boat also has a Convex V hull. I believe that in 2003 they revised the Convex V hull to make the rocker more pronounced. This happened again in 2005 with the introduction of the Ve series.
I'm not normally one to call into question Mr. Know It All Tige Guy.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
