Just got the upgrade kit for a Wakeboard Pro Mechanical. The kit includes a new Master Module with Version 7 software, a Garmin GPS18x-5Hz receiver & an Operating/Installation Instructions book. If you have the older single line display you will need the newer multi line display. The GPS receiver replaces the paddle wheel function, but does not have water temp. It is a 12 channel unit that is 2.4" across. If you already have a paddle wheel/temp sender there is a port on the master module for it so you can still get water temp. I always forget about the System Info page which has - software version no., battery voltage, engine selection, hour meter and water temp. There is a new GPS Info page with Lat, Lon & clock.
Perfect Pass Stargazer Upgrade kit
Originally posted by yellow3 View Postwhy is that???Common Sense is not so Common
Originally posted by jake's02-22i View Posti thought they sold them the patent.Common Sense is not so Common
Originally posted by R&T Babich View PostI always forget about the System Info page which has - software version no., battery voltage, engine selection, hour meter and water temp.
Originally posted by noworries View PostWater temp, at least, can be enabled to show on the Wakeboard page so you don't have to go to system management to see it.
