07 RZ 2 a pig out of the....
    Any one else having trouble with their 07 RZ2. I had the 400 hp put into it because I wanted plenty of power. The only thing I have is a headache...the taps plate has to be at 1 for me to get on plane with 6 adults and 4- 50lb kids in the boat...no water in the boat either!!!
    HELP
    What prop is it running, what is the altitude of your lake? Sounds like the wrong screw
      I am at Tahoe, 6000 ft. A 16 prop.
        HELP
        Something is wrong, I have the 24Ve and run with ballast all the time, and it still pulls well. I only have the 340 HP engine. Recently, I had no ballast in the boat, it had been a while, it felt like a rocket. Hope its something simple for you.
        http://wake9.com/
          Oh yeah, I think the hi-alt ACME is something like a 13 pitch. Did you buy new from a local dealer?
          *EDIT* Reread your 1st post, looks like you ordered the boat to your spec's. Dealer should have made sure it had a better suited prop on it.
            Tahoe is def going to suck some power. You need to speak with someone with experience up there for prop size and stuff.
            http://wake9.com/
              I'm at altitude with the 340HP and an Acme 537 and we run ballast all the time with no problems. I think something else is wrong.
                Did you take the boat off of the trailer?
                "the plural of boo is booze."
                  I have ran my RZ2 at Union Valley, CA with minimal power issues. At 4380 like you are, there shouldn't be issues like you are saying. Have you drove your boat <2000 feet elevation?
                    Yeah, I'd be curious what the top speed and WOT RPM are! Timmy poked a hole in the prop theory
                      With the 6.0 engine I believe you have the Acme 381 which is 13.5 x 17.5, you might want to try an Acme 537 prop which would be an 13.5 x 16.
                        Even then I can hit 40/41 up here and my home lake is ~ 5,400'
                          I agree, Lee thinks he might have the wrong prop on there for the elevation. I would happen to agree since I have ran my RZ2 at 2600 with the Acme 537 without an issue. Yes, does take longer to get to plain but I can do it.
                            You might want the 857 which is 13.25 x 15.5 with .060 cup instead of .105 cup.
                              Do they put a different transmission gear ratio in for boats at altitude? I know my Rinker had different gears for the elevation so you could still use the same pitch prop as sea level.
