I have an 04 22i with a Tige tower. There is no hole in the bottom of the tower on the left side or the deck to run speaker wire. Looking on the inside where the tower mounts there is no hole either and the hole on the right side where the light wire is, is only big enough for that wire and I need to run tower lights through there. It looks like I will be removing the bottom sections of the tower and drilling some holes. Any input ?
Tower removal
