I purchased a second battery and a West Marine Battery Combiner for my 2000 21i. I'd like to run the stereo off of the second battery, but I'm not sure how to wire it.
I noticed there are 2 positive wires going to the starting battery, 1 huge one, and 1 small one. At first glance, I thought this would be simple case of installing the second battery and combiner and wiring the huge cable to the starting battery and the smaller cable to the house battery. However, the stereo is somehow wired to the huge starting cable. I know this because I connected only the small wire to the battery and attempted to turn the stereo on....no luck. I then attached the huge wire and tried the stero.....wallah, there was power.
So, I need to figure out how the stereo is wired into the starting power, disconnect it, and wire it into the second battery.
Any help would be greatly appreciated! Pics would be great as well!
Thanks a ton!
- Scott
Thanks a ton!
- Scott
