I was getting too much water in my 2004 20V. I took it out of the water and noticed some water coming out of a small hole about quarter inch in diameter (maybe a bit less) situated on the starboard bow side about halfway from the rub rail and the very bottom, just below where the bow compartment under the starboard bow seat is, the hole is about 2 to 3 feet from the very front of the boat. It is below the water line when in the water.
Question: the hole looks pretty "clean" I suppose, could it be where some sensor input goes? Or did I hit something that poked a hole in the hull, it sure does not look very thick there? Thanks for any information you have . Tim
