wattage of alternator
    Does anyone know what size alternator they put on tiges? I need to get a new one, aka, with the amps I have in my boat it just can't cut it. I have an 03 21ir with the 350 315 merc in it. Thanks.
    Plus does anyone know if the high out put off a malibu would fit? I can get malibu parts at cost(friend deals in them) Thanks for the info.
    Dom
    Originally posted by G-MONEY
    Should be 65 amps.
      Check out this 210 amp http://www.wakeboardatlanta.com/litup/products.html
      Dont know where you could buy it, but the owner of Lit Up Electronics is based here in Dallas.
        It might not be USGA approved.
          That's what I need!!!!! I'll look into where I can get that.
          Dom
            the 65 just can't cut it. I need more power!!
            Dom
              your best bet would be to contact an alternator shop and have them build you a custom alternator to your suit needs. just remember, if you put a high amp alternator in be sure to upgrade your charging wire harness or you could melt down the electrical system.
              Greg Denton
                When I bought my boat, the Ski Dock recommended that when I fuel on the trailer to make sure the bow was even or lower than the stern or otherwise I would get back pressure on my '99 21V that will cause fuel to spill when the tank got full. Consequently, when I fill up on the water, I usually put some weight on the bow to compensate and have had no problems.
