Clogged lake water intake
    First off I have a 2001 21i, while I was out this last weekend I was camping where there was a lot of wood debris. I think some of this debris got sucked up and I overheated and had to be towed back. I know on my old inboard there was a screen right before the transmission cooler that debris would get caught in. Is this the same for the tige inboards??
    Tige does offer a raw water filter as an option, but dont know for how long back. Just fallow the hose from the tru-hull scoop to the trans and see if it has one.
    I would remove the inlet hose at the raw water impeller housing and back-flush the system if no strainer is present. Good luck.
      There was a screen where the water enters the transmission cooler after leaving the impellar housing. I pulled the hose off the transmission cooler and the screen had all sorts of debris wedged in it, pulled it all out and problem solved!!
        Post some pics when you get a chance.
