On a 2006 20V with the GM Vortec 340 HP, is there an impeller part for cooling, or is that the older motors? I have heard about changing that part when winterizing, but is that on the 2006 GM Vortec 340 HP?
Warning...Stupid Question
Guest
Question is far from stupid if you don't know the answer. The answer is yes the Vortec does use an impeller. What I don't know for sure is if the 2006 GM Vortec 340HP is a Marine Power marinized motor or a Merc. If you are a do it your selfer the Block is stamped Marine Power if it is one.
If you need an impeller you can buy one from one of the members. Contact SPBFAN and he can set you up with what you will need.
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
He has the MP 340?
It has GM Vortec on the air filter cover.Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
and yes you need an impeller and will have to change it every 1-3 yearsPut your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
