I am thinking of putting on an FAE on my 20V and am wondering how far from the transom does it stick out?
How hard is it to disconnect from swim platform with quick release kit?
If you loosen the hose clamps can the down tube be rotated up for storage so it is positioned closer to the transom?
I store the 20V in a 21' 5" garage and with it in the normal mounted position it does not look from pictures I have seen that it will fit. I need to remove the swim platform to get it in now and depending on how far the FAE sticks out I may or may not have to pivot it or even worse remove it. If I have to remove it to store the boat between trips in the summer it won't be worth it.
