Anyone know what RPM the 340hp Marine Power is supposed to idle at? Yesterday while I was waiting for my buddy to bring the truck to the ramp it seemed like my boat was idling a little on the low side, seemed a little rough. It's idling in the 600 rpm range when not in gear. Is that right?
RZ2 340HP MP - what's idle RPM?
If it is running rough, then it's probably misfiring. Stepping up the idle will only mask the real problem. You may want to have him check his plugs to make sure they are in good shape and making good connections with the plug wires.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
If it feels rough, could indicate that he engine and drive train may need a realignmentMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by Timmy! View PostIs that a normal maintenance item? I have 102 hours on the boat now.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
OK, from the Marine Power Owners Manual:
Check engine mounts: After 1st 10 hrs, every 100hrs, Once a year.
Check Prop and shaft Alignment: Once a year.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
