Originally posted by flyguy
View Post
How to get lake temp on Z1
Originally posted by flyguy View Postchpthril, the triducer is there already in the Z1. The problem is there is no display up on the dash... there is no settings with the speedset to show the air/water temp. It sure would be nice to swap a 20V gauge package into the Z1 to allow the temp to show.
Z1 Lake Temp
Sorry for the delay guys.
Currently you have this in a Z1 with Depth option
Tach: oil, eng tem, volt
Speedo: set, actual, depth
It is correct that lake and air temp are not options for this model. Now the dash mini harness has the air temp built into it already. The triducer also has the water temp built into it. Everything is there for it but it is not in the gauge package you are using.
Getting a Z1 to have air and lake temp is not an inexpensive task. Here is what you would have to do:
20i/20v/22i gauge set (tach, speedo, 4 in 1) and mini box. The issue with this is where do you put the 3rd 5" gauge, which is a 4 in 1. You will also duplicate the fuel level indicator.
If you run the 20 series tach you would get air lake and depth but you would loose oil pressure, engine temp and volt. I would not recommend that route.
The last option would be to run the b/w screen used in the RZ and VE models and re program the mini. Again a very expensive route to take.My TAPS goes to eleven!
This might be an option but the cord seems like it might be a bit short. Maybe there are others out there that could be used.
http://www.cabelas.com/prod-1/0052661320351a.shtml
Originally posted by Waterski-Rebel View PostWhat is the CAN bus?
It's a means for computers and sensors to transmit dataMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I just found this online, I also ordered one. It is onsale for $8, and shipping is another $5. It's not the perfect solution, but it does have a 20 foot cord on it.
http://www.cabelas.com/cabelas/en/te...equestid=54811
Originally posted by Waterski-Rebel View PostI just found this online, I also ordered one. It is onsale for $8, and shipping is another $5. It's not the perfect solution, but it does have a 20 foot cord on it.
http://www.cabelas.com/cabelas/en/te...equestid=54811Work Hard, Play Harder
