My boat is running rich, yo can smell is when you get to the exhaust. I had replaced the fuel filters last time and now the boat will not go past 25 mph. the boat seems to run fine but it does feel a little tired, thats when I noticed the smell. I am not sure what kind of sensors are used to deternime air to fuel ratio on this motor and also the vaccum hoses. If anyone has any idea what could cause the boat to run rich and what to check for please let me know. Thanks to everyone who helped me with the fuel delivery issue last time.
Boat is running rich 02' tige 350 mpi
Originally posted by soccerboy007 View PostMy boat is running rich, yo can smell is when you get to the exhaust. I had replaced the fuel filters last time and now the boat will not go past 25 mph. the boat seems to run fine but it does feel a little tired, thats when I noticed the smell.
I had this problem on my 04 with the same engine.
I turned that my ECM needed to be reprogrammed. (The battery died on my one day, so I had to jump start the boat. Doing this cause the ECM to lose its program. I have also herded that charging the battery with the master switch in the on position; can also cause the ECM to default back to the factory settings.)Tige, it's a way of life!
Originally posted by soccerboy007 View PostI have take all the fuel out and put new fuel in there. I dont know where the master switch is at so please give me some instructions of where its at.Tige, it's a way of life!
