The engine may have leaned enough to foul the plugs. That's an easy item to check.
I need help with an 02' tige 20i.
Ok, on your Merc MPI, if you haven't changed your distributor cap and rotor, then it's time to do so. I have to change mine about as often as the impeller. The distributor cap wears out unusually fast on this engine.
The other thing I had happen recently is that my fuel pressure regulator went out. It was still working fine, but it did alarm on the engine any time I went over 2500 RPM. My dealer told me that eventually it would stop running completely, in other words, I would lose power after a while. The regulator is attached to the outbound side of the fuel cooler. It should be easier to get to than it was on my V-Drive. It might be worth it to have someone hook your engine up and see what codes are being generated, or, better yet, check the fuel pressure.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Originally posted by soccerboy007 View PostThe rotor and cap were replaced just recently it does have a knock sometimes but its not consistent. could it be fouled plugs?
Thanks you guys I finally figured out the problem it turned out it wasnt fuel related but ignition related. I followed dogbert's recommenndation and changed the cap and rotor.Then it hit me electronics 101 always check your source of ignition. It turned out that the ignition control module was bad. But thanks to everyone for all you help.
Originally posted by soccerboy007 View Post... It turned out that the ignition control module was bad. ...
Originally posted by dogbert View PostOk, on your Merc MPI, if you haven't changed your distributor cap and rotor, then it's time to do so. I have to change mine about as often as the impeller. The distributor cap wears out unusually fast on this engine. ...
Originally posted by R&T Babich View Postdogbert - what wears out on your distributor caps? That seems unusual. Do the contacts get grooved, because that would indicate the shaft bearing is worn and allowing wobble in the shaft. If the contacts are all pitted, are they brass or aluminum?
They are aluminum, so I'm sure that's part of the problem. The rotor doesn't seem to go bad, but I have spares for both just in case. I've only replaced the rotor once, but am on my nth distributor cap (I lost count). It gets so bad that after a while, your boat won't even start.
This is one of the things that was much better on the Marine Power engines.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
BTW, I never had this problem on my 4.3L V6 Mercruiser. In fact, in the 10 years I owned the boat, I don't ever recall changing the distributor cap.
It appears to only be a problem with their Tournament Ski Mag engine line.
Go figure, buy their top-of-the-line performance engine and have these problems.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Originally posted by dogbert View PostYou would think so, but not according to my service tech. The contacts don't get grooved, they appear to wear from arc'ing
They are aluminum, so I'm sure that's part of the problem. The rotor doesn't seem to go bad, but I have spares for both just in case. ...
I'll bet your 4.6L cap had brass contacts.
Originally posted by illiniboarder88 View PostIs there a fuel filter on that line other than the fuel water seperator? If so, how hard was that to get to?
p/n's : NAPA: 3225 (18-7844) (MERC: 35-60494-1)
Hope this helps.Dale
2000 21i Tige
