how often does this need to be replaced...yearly?? or hourly, if so after how many hours, thanks, again.
fuel filter
^^^^ yep.......@ winterizationMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by Jason B View PostI thought it would be best to do it after the first tank of gas each year. Am I wrong? I read that somewhere, couldn't tell ya where, but it made sense to me.
If you live in a dry area, you may accumulate a little water through the course of a season, that will be removed with a filter change at winterization.
IMO, just do it, when ever, once a season.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Hard to believe you need to change it every year, unless you get incredibly bad gas. On my 71 Correct Craft, which had the inline filter, I'd just pop it out, blow into it, and if there was no resistance, good to go! I think I changed it 3 or 4 times in 35+ years! Now, I guess I have to find where it is on the 20V!
Open engine cover and port storage lid, remove divider between engine comp and storage. Filter/fuel cooler housing is on front/port side of engine.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by paulct View PostHard to believe you need to change it every year, unless you get incredibly bad gas. On my 71 Correct Craft, which had the inline filter, I'd just pop it out, blow into it, and if there was no resistance, good to go! I think I changed it 3 or 4 times in 35+ years! Now, I guess I have to find where it is on the 20V!
And I also change mine after the first tank of the season. I do this as it might have accumulated some water over the winter. ( rather start the season with a fresh filter, instead of trashing a new filter first time out)Last edited by whitlock87; 05-29-2008, 12:51 AM.Tige, it's a way of life!
Originally posted by illiniboarder88 View PostIs there both a fuel filter and a fuel/water seperator?
