Does anyone know how to do this? I cannot figure it out and prying it with a screw driver does not see to work
Raising the V drive floor plate in a 2007 20v
Originally posted by kko View Postthe center of the rear seat has to come out. there are two screws on the rear of the floor plate holding it down. what are you after?
(You will have to remove the cartpet stip from along the bench to remove the center peice)
If you need it, I can take a few pics and post them.
David W.Tige, it's a way of life!
Originally posted by Bandsecurity View Postsome have said lagged and others through bolted. That is why I am concerned. I would like some picks. I wish I knew for sure.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
