04 22v fat sac question
    Looking to add some fat sacs. the rear locker in my boat is roughly 38 x 22 inches. The Pro X Series V-Drive Wake Surf Sac dimensions is 42 x 16 x 16. Is it acceptable to allow the bag rest on the inner part of your boat? Or do you want it free standing. For example, the MasterCraft X-2 Rear Sac dimension is 32 x 18 x 20 which will fit fine in the rear locker (with room to spare) and holds an additional 50lbs. If I get the X-2 Rear Sac will the Valves cause a problem for me if I get the intergrated bow sac. The valves for each are differeny according to the picture. Any information will help. Don't know much about this area of boating.
    http://www.fatsac.com/FlyHigh/FlyHighSacs.html
    Ihave the flyhigh 750 on top of my factory ballast and have problems
      What problems have you had?
      The laughter of the world is merely loneliness pathetically trying to reassure itself. - Neal A. Maxwell
        No problems the sac fills the locker everything just kind of molds to it, just make sure there is no sharp objects in the locker
